Hi all,i have a p3s,which is stock,no mods ,just wondering how to get more distance from it I only get about 900 ft at the moment any help please,many thanks.
Something is wrong with it, have you ever seen it work better?Hi all,i have a p3s,which is stock,no mods ,just wondering how to get more distance from it I only get about 900 ft at the moment any help please,many thanks.
1,500-2,500ft in ideal conditions, although maybe 500-1000ft around concentrated electrical noise. With the parabolic reflector just over 4,000ft Ideal conditions, around 2,000ft in non ideal conditions. Before I opened up my controller to mess with aftermarket antennas the above stats were pretty consistent. Although everyone's statistics are subjective to their test environment. I've heard of people getting 1mile stock and I've heard 400ft. You could be right RodPad. Although I sure thought there was something wrong with my RC until I drove around on my days off work testing range from Lawrenceburg, Indiana to Hebron, Kentucky to Dayton, Ohio then back home in Anderson hills Cincinnati, Ohio where I live. Very first flight with my p3s around my home in the suburbs resulted in around 700-1000ft. I later learned all the several hundred wifi networks nearby interfered with my connection.Something is wrong with it, have you ever seen it work better?
What happens when you loose signal?
@New Phantom Owner,
900 ft, he should be getting 2000 ft in clean air without mods.
I would guess a football kicker could get close to 900'
What did yours get before you did your mods?
Rod
@New Phantom Owner,
What was happening when you lost signal?
@mark191,
What happens when you loose signal? How does your signal loss manifest? Which bandwidth is lost first and under what conditions?
Rod
@New Phantom Owner,
This was the question.
"What did yours get before you did your mods?"
From above post: My answer was,
Rod
