Hello there,I got an error that I've never seen before while flying the Phantom 3 Pro today. I updated the firmware and App a few days ago when it was released and I've flown about 6-7 times prior (after upgrading the firmware and DJI Go App) without any problems.
Today while flying the gimbal got floppy for a second and then I got an error in the DJI Go app saying "Compass Error, Exit P-GPS mode" and had to fly back in Atti mode. I toggled the modes on the controller from P to Atti mode to see if I could get it to reset and it did not reset until it was almost all the way back home.
No crash or damage but it was strange because I have never seen that error before. I had calibrated the compass in the same place just a couple flights prrior and it worked perfectly prior to that flight. I flew again from the same location and had no other issues.
Any ideas?
Thanks,
Scott
My Youtube Channel
Is everyone that is having this problem on the new firmware 1.3, really hope this is not a another new problem. Wish they would stop bringing out new aircraft and just get the ones they have made to work properly. I thought we had finally got a good firmware until i read this thread and now i have a bad feeling about this. I have had compass errors at low altitude before near metal but never mid flight up high, now that is a real worry cos i fly faaaar.
same as me, i redid the compass calibration every time i take off from diff places. i warm up the craft, after that I recalibrate then i armed the motors. during flight my app always crashed...so what i did i disconnect the usb and reopen app. after that i connect the usb to phone. this way i get good video feedback and less APP crashes.I had this problem and was able to bring it in with no issues. I redid my IMU and haven't had the problem since after 10 flights. Make sure you put your P3 on an air vent in your house for 10 minutes prior as my IMU was done at end of day and every successive flight was a painful 2 minute IMU warmup period.
There were compass errors reported before 1.3. Unlikely to be the cause.
yes come to think about it I have seen it many times right after a quick 30ft or so shot upGuys
The gps mode degradation is there for a reason. Like others have posted without a valid reading bad things can happen in gps mode. So when the logic detects this it drops down into a pure atti mode.
I have only seen this when I push the craft hard right after take off. It usually recovers in a few seconds.
I don't know about you but I would rather have it do this than have a fly a way type scenario.
I disagree. GPS navigation does not require compass.In a compass error GPS navigation is afected and you could have a flighaway.
To prevent that GPS mode is disabled because GPS mode needs compass to navigate.....
Disabling GPS is the thing that causes the flyaway.
Think about it like this: the craft knows its current position. Even if it does not know its compass orientation, it could navigate relative to its previous position. While the algorithm may require converging to a true orientation, it would be much better at hovering, than no GPS at all.
This and other threads, show where the next improvement dji needs to make: better orientation sensors that stay reliable without needing recalibration.
Sorry but you're 100% wrong.. without a compass the craft can't fly in gps mode..This is what causes a flyaway, the system listening to bad compass data.
