Max P3P sd card write speed?
Dorset, UK
Please excuse if this has actually been discussed already! (I cannot find the answer)
What is the max write speed of the P3P?
I notice class 10 UHS-1 micro sd cards have vary different "write speeds"
(This is true of the "read speeds" quoted on the front of the packs too)
I am probably going to buy a Sandisk extreme pro 64GB - as it quotes both "read" & "write" of about 90 / 95 MB/s
Is this complete overkill if the P3P only writes at maybe 40 / 50 MB/s (for example) ??
Supported SD Card Types Micro SD
Max capacity: 64 GB. Class 10 or UHS-1 rating required
Max Bitrate of Video Storage
Phantom 3 Professional
60 Mbps
Phantom 3 Advanced
40 Mbps
Doesn't hurt to have a better card, and it's not a significant price difference for a slower one anyway.
Reactions: JustinJ
A lot of people like to quote the above video specs (which is 7.5MB/s max). Don't forget the Phantom saves large photos and you'll be transferring files back and forth between your computer.
The SanDisk Extreme (40MB/s write speed) would be a good choice too if that small $$ savings is important to you. If speed is most important, then go with the SanDisk Extreme Pro (90MB/s write speed).
Reactions: JustinJ
Thank You for very prompt replies @bbfpv & @msinger
I will proceed to purchase a sandisk extreme pro 64gb - it's only £33 (or $50)
I think that is a very reasonable price!
(when I compare both the read and write speeds of the other sd cards)
That's a good card, I use it in my bird. It's actually 95MB/s. In my cameras I use the 160MB/s cards.
Sent from my iPhone 6+ using Tapatalk Pro
Reactions: JustinJ
Or, you could save your $$.
Paying for the fastest card gives you no advantage except copying files across to your computer.
The Phantom is the bottleneck - not the card.
