Max altitude reached/30m. Change in mc settings if needed
Increase the following setting in DJI GO (while your Phantom is connected to DJI GO) if you need to fly above 30 meters:
Also, make sure Beginner Mode is disabled since that setting can also restrict the max altitude.
Yap, begginer mode is off, and max altitude is 500. But i manage to fix it. I just remove homr point, and put it back again
I got this msg tofay. Anyone know what is the problem?
You probably are in beginner mode. It’s easy turn it off. Just read the manual . My advice, fly in this mode a couple or times to practice a little bit.
