Map Pilot issue start point
Hi guys,
I have a problem with Map Pilot.
My P3A goes until the right altitue, then he doesn't go to the start point.
I don't understand the problem.
Thank you.
Not being snide, just want to make sure I under stand. The mission lines show up on your screen? And You did properly upload the mission to the bird, correct?
Hi Richard,
It's all ok...data, upload, etc ...
I push star botton, the mission start and the bird goes until the right altitude.
Then, it would go to the start point but it don't do it!
Three days without solution...
Ps. DroneDeploy completed 10% about the mission then stop!
DroneDeploy "remembers" where your mission left off. So it should automatically select a start point relative to your mission progress. You can change the starting or resume point under Advanced settings. There's a slider for it.
If you change the grid orientation between mission progress points you might somehow be voiding your previous progress. Have you tried making a copy of your mission and running the copied mission from the beginning?
Also, make sure you calibrate your compass prior to flight. Your bird might want to go in one direction while your mission might want it to go elsewhere. (I know. It's a reach. But better safe than sorry.)
apktuti
