TEST
Above is a link of an area I mapped. It seems like the elevation gradient doesnt quite match the 3D model.
The 3D model shows a few elevated mounds and the elevation data shows just a gradual decline in elevation.
Is that because of the resolution of the elevation scale?
Is your map showing up in the correct location? The basemap doesn't appear to match your UAV imagery. Curious because if the GPS data is errant, then it could be leading to incorrect model creation.a link of an area I mapped
Ok, just wanted to double check. You're right that the color DSM doesn't appear to be showing some of the subtleties that you would expect. For example, you can see the slight elevation difference between the walking paths and "runway" (what is that by the way?), so you should be able to see the bigger terrain features as well. The color legend is giving measurements, but it's still a gradation on the map.Ya it is in correct location.
you are correct, it is a runway..lolOk, just wanted to double check. You're right that the color DSM doesn't appear to be showing some of the subtleties that you would expect. For example, you can see the slight elevation difference between the walking paths and "runway" (what is that by the way?), so you should be able to see the bigger terrain features as well. The color legend is giving measurements, but it's still a gradation on the map.
Nice work! Have you tried experimenting with any of the professional software? Everyone has free trials for at least a month. You could compare those results to the MME maps.I mapped the local RC park
The color bar at the bottom is just the reference scale, you will get finer color gradations in the actual map. As an aside, maybe you can help me with an issue I'm having with MME. With my first P3A, my elevations were compressed. That is a building that was 8.5 ft on the side showed as 2-3! And my average height agl was down by about 40% (showing 120 ft when actually at 200). Flew a second P3A with the same firmware and the elevations are more nearly correct but average height now 150 not 200. All the log data shows that the bird flew where it was supposed to and the terrain is flat or sloping down. Not getting any satisfactory answers from MME. How does your info look (especially the average height)? Curiously, all of the ortho maps look very good, distances and 2d sizes are spot on!
