- Joined
- Jun 29, 2014
- Messages
- 5
- Reaction score
- 0
I made a post just above yours. You cannot buy just the quad, you have to buy the entire package.
If you seal (waterproof) your quad it will heat up big time (and that will screw up its altimeter).syotr said:Even with floats, you are likely to tip over. Have you considered a waterproof quad?rightoncue said:Next time, floating landing gear, yup, not gonna screw that up again.
There are several waterproof quads. Some have used heatsinks through the shell. They usually have vent to let the inside and outside pressures equalize.slothead said:If you seal (waterproof) your quad it will heat up big time (and that will screw up its altimeter).syotr said:Even with floats, you are likely to tip over. Have you considered a waterproof quad?rightoncue said:Next time, floating landing gear, yup, not gonna screw that up again.
