losing gimbal screw
AZ
Any body else have this problem, I have flown it twice and have lost a
T screw twice.
Phantom2 zenmuse with gopro.
Its one of the T screws thats flush on the body.
You referring to the screw that holds the holds the 2 flat mount brackets together? If so, i have lost a complete set when i crashed mine. Was able to find a set of 6 for $40. Wish there was a cheaper alternative.
Yea $40 for those little screws is absolutely crazy. Might try and find something else to fit through the hole that will do the same purpose.
well, I'm thinking, why not just put some zip ties in there somehow. if you do it right the plate is centered and won't drop.
I was also advised to use zip ties, I ran a small wire through and twisted it.
No probs since.
will switch to zip.
A pretty common problem. Zip ties are the simple solution.
Sent from my iPad using Tapatalk
jadabyanza24
