Mark The Droner
Premium Pilot
- Joined
- Aug 26, 2015
- Messages
- 5,349
- Reaction score
- 1,772
I wasn't aware that a Litchi mission allowed control of the gimbal other than manual control.
Mission Hub - Litchi
im going to try now, i believe its actually when you have the Curve setting activated it wont alow you to change it.I'm pretty sure when you press way point then look to the left of the screen you'll see a settings button. Click that and you'll see the different options of what you want the gimbal to do. I think you have to scroll down and it's the last option.
1 question for mission using waypoint. If lose signal are the bird will finish the mission ?
Did you get it figured out? Now that you mentioned that you might be right. I think it might have to be set to straight lines.im going to try now, i believe its actually when you have the Curve setting activated it wont alow you to change it.
I already check .. i set hover.When a Litchi mission is finished, it hovers at the last waypoint and awaits your command.
Will check that.. thanks broShould be in your mobile device files under LITCHI\LOGS
Yes .. the bird camera will point to POI . Cam gimbal pitch will follow high of the poi setting.its definitely straight lines. if you then put inerpolated i find it flys doing a 360? and if you put poi focus it flys looking exactly at the POI. stupid question so if its flying a mission can i not control the camera? in flight?
Yess .. my app keep crashing.. i cant open litchi now....Anyone having issues with app since last update?
i forgot that i registerd on litchi beta tester program.Yess .. my app keep crashing.. i cant open litchi now....
just back to 3.4.0 ..Anybody updated to 3.5.0_BETA? I installed this latest update this morning. After which, Litchi would crash on start-up.
This happens on both my devices (Sony Xperia Z3 Dual and Lenovo A3300). Anybody else having similar issues?
I have contacted Litchi and still waiting for their reply.
