Litchi
I'm pretty sure when you press way point then look to the left of the screen you'll see a settings button. Click that and you'll see the different options of what you want the gimbal to do. I think you have to scroll down and it's the last option.
im going to try now, i believe its actually when you have the Curve setting activated it wont alow you to change it.
1 question for mission using waypoint. If lose signal are the bird will finish the mission ?
Did you get it figured out? Now that you mentioned that you might be right. I think it might have to be set to straight lines.
Helo.. may i have question.... litchi waypoint why after mission finish it always RTH auto land.
I already set hover. And already recheck on map plan.. its hover Not RTH.
When a Litchi mission is finished, it hovers at the last waypoint and awaits your command.
I already check .. i set hover.
But always after finnish last point.. then trigger RTH.
So i switch to p mode to take over the controll. Something wrong ...
its definitely straight lines. if you then put inerpolated i find it flys doing a 360? and if you put poi focus it flys looking exactly at the POI. stupid question so if its flying a mission can i not control the camera? in flight?
Yes .. the bird camera will point to POI . Cam gimbal pitch will follow high of the poi setting.
Reactions: WLS350Z
Anybody updated to 3.5.0_BETA? I installed this latest update this morning. After which, Litchi would crash on start-up.
This happens on both my devices (Sony Xperia Z3 Dual and Lenovo A3300). Anybody else having similar issues?
I have contacted Litchi and still waiting for their reply.
just back to 3.4.0 ..
3.5.0 will crash............
jorge sanchez
