Litchi Interpolation Question
San Francisco Bay Area
I have a 10 WP mission which executed just fine except for interpolation. The first 2 WPs are normal with just height, speed, and heading defined. WP 3 is the same except Interpolation is set with gimbal pitch set to -90 deg. WP 4 is also set to Interpolation but with gimbal pitch of 0 deg. When I ran the mission Interpolation did not execute between WPs 3 & 4. Path mode is set to curved turns. Not sure if that is causing the issue. Is there something I forgot to set correctly?
Hi, interpolation does not works with curved lines, only with straight ones
The finn
It does not mention in the manual that Interpolate does not work with curved lines. I know Action do not work with curved lines because the ac doesn't get to the WP to trigger the action. But Interpolate is grouped with POI and there is no issue with POI. Unless it prioritize POI over Interpolate. In any case, I will try turning off curved lines and run it again. Thanks.
