- Joined
- Aug 17, 2020
- Messages
- 329
- Reaction score
- 213
I acquired Litchi specifically to fly pre-planned autonomous missions, so in this regard it has performed flawlessly and above my expectations. The work-around solution to address the lack of gimbal tilt control when flying beyond signal range, has been solved by contributors to this forum, who advise disabling the gimbal tilt facility for all waypoints, and then manually setting the gimbal to the desired angle right after takeoff, but BEFORE pressing the play button to commence each mission, whereby that initial manually fixed gimbal tilt angle is maintained for the entire flight, regardless of controller signal limitations.
The problem I have encountered in manually setting that gimbal angle, is that for all of my most recent flights with Litchi, the sky and horizon view, on my iPad, has been completely obscured by strange black and white bars that resemble the zebra crossing markings seen on city roadways. Additionally, those zebra crossing markings also appear on any bright or shiny surfaces such as roofs, or puddles of water on the ground, that are visible on my iPad's FPV screen during flights using Litchi. With those annoying bars completely obscuring the horizon in my iPad's FPV view of the flight, it is practically impossible to manually set the gimbal tilt to the desired angle, with the result that I would up turning the camera almost vertically downward for my last flight, pretty much ruining all the footage.
I would be very grateful if anyone can explain how I can go about getting rid of those strange zebra crossing markings that prevent me from seeing the FPV screen horizon, and thus make my initial gimbal tilt efforts a trial-and-error, hit-or-miss endeavor, rather than the simple precise adjustment that I expect to be able to perform when I go to frame my camera's gimbal view for each flight. Those strange markings do not appear at all in the recorded footage, but only in the FPV footage, and also, there are no such problems in the FPV view when I use DJI Go. I am pulling my hair out here, over trying to figure out why the horizon is so completely obscured by those odd markings, yet I have no idea how to get rid of them, so I can regain full control of my camera view when using Litchi. Thanks in advance for any help that can be offered.
