LED front lights not working
Hello,
Did any one every run into this trouble where the LED lights dont work? Everything else works great!
Is it just simply solder a working set on or is it something greater then that?
Did you check if you have them turned on in DJI GO?
Im having this issue on my p4 standard. Ive checked the setting and its set to on however my front leds never come on? Everything else works great.
You can also control the LEDs using the C1 and/or the C2 buttons as detailed here: - How do I turn OFF the front LEDs for night photography? For a P3 but I would guess a P4 would be similar.
It may not sort out your problem but it's worth a try before you start delving into opening up and checking wiring and circuit boards. But I find it unlikely that the two front LED units would fail simultaneously, so the cause could be elsewhere, maybe even within the dji go app itself. You could perhaps try removing the app and reinstalling.
Reactions: N017RW
akos9703
