Planning to launch in a clearing in a dense forest. Probably I won't be able to get enough satellites at launch for P mode, but once above the trees there should be plenty visible. Will my P3 Adv switch to P mode as soon as enough satellites are visible ? (guessing it will.) What about the home point? Will it record the point directly under where it is when it enters p-mode?
Flight plan is to launch in A mode, go up to 100 feet and hover, switch to p mode (actually, f mode), then fly a fixed heading while filming. Since trees may block visual of the drone when it is downrange, proper recording of the home point is vital in case I need to RTH with no visual contact.
