Just Lost my PSP while in litchi mission , need help !
I thought I read the thread, I didn't see where he stated it hit something? What post #?
thanks
Great ending, so happy for you! Elevation changes are a real problem.
I too had a close call & I took the time to look over my flight path not even noticing the gradual change in elevation from point 1 to 14!!
Reactions: Technikal
You obviously have not followed the whole posts or watched the video.
let me know when you have and then you will understand what lesson was learnt
I just thought this was something bizarre that happened, so I was making sure this wasn't a Litchi issue, this is a make sure I know the terrain issue.
gotcha
In the start i personally assumed it was a litchi issue , as I have used litchi missions over 20 times . I just changed phone from iphone 6 plus to samsung Note 3, andriod . This was my second mission on it , expecting the drone back as normal even after signal loss, but at the end of This adventure , realised it was my own fault "user error, Terrain changed " whitch caused the crash . This was my lesson lernt . Shared for advise and prevent others from getting in the same situation as I did.
Sent from my SM-N9005 using PhantomPilots mobile app
Just noticed it states it landed with 92% battery after 1min 34secs and the picture shows green line at end.
but thats not possible because i walked about closer and arond the are with remote still on and no signal
It's possible. I had a crash due to bad RTH altitude configuration, and my P3A was always on. I found it visually with all the gear connected and never had video. Even after I had the phantom in one hand and the remote on other.
I fly Litchi, when filming a golf course I didn't realise the hole was 8 mtrs higher than the start point. Nearly took the flag out with the Phantom !!
Glad your story had a happy ending... well, double happy ending... found it and no problems with it.
Watching your video... I get that "Oh no!" moment as soon as I see it brush the first tree.
So how do you prevent something like from happening?. I do not have Litchi, I use Autopilot but I have been thinking to go with Litchi. If I use the Mission Hub how will I know the terrain changes.
Hub will tell you ground altitude difference between first and every next WP you add. You need to take care of obstacles
Got it, I see it. It tells you in the "Ground Elevation: 414ft (22ft above first waypoint)", It is the footage above first waypoint.
