Is there an optimum memory on SD card ?
I have periodically been having trouble with My SD card. Every now and again I have to reformat card. It keeps stopping working. I keep losing footage because if this. It is so frustrating when You get somewhere to do a flight, and even after reformatting, it won’t record onto card. Making yet another card useless. I never buy cheap ones. Either Sandisc or Verbatim.
But a friend told Me recently that He has read somewhere that a maximum of 64 gb should be used. Surely if this were the case. You wouldn’t have to search for such info. It should be clear in the instructions in box ? Has anyone else heard this. Of had similar problems ?
Thanks in advance, this forum is the best for fixing anything.
See here: What is the max size SD card that can be used in the Phantom 3?
Found using the search function (magnifying glass, top right)
Reactions: blomdido
Perhaps your friend was reading the P3A specs? That's also mentioned in the P3A manual.
Even though, some people are using larger memory cards.
Reactions: blomdido
You can use larger cards but they don't work any better.
There is no optimum size.
Reactions: blomdido
That was really helpfull. Thanks. I’m going to go for multiple 64 gb cards. Also makes sense in case of loss if data.
Yep, that's a good point also. I was going to mention it too, but you've already spotted it for yourself... :)
Or you could use smaller cards.
Storing precious images on a big card and sending it back out is not a great idea if you value your work.
Reactions: RunningWithScissors
+1! I used several 16gb cards. I record in my log which one I use for each flight (change it out before each flight) so I can rotate them just like I do batteries. I make it part of my standard routine to download the imagery to my laptop as soon as I get home and I reformat the card in the bird prior to taking off. Doesn't guarantee that I'll never lose any data, but should help reduce the risk.
jorge sanchez
