Professional Is the latest P3P FW v 1.3.20 a VLC Media File (.bin)?
Discussion in 'Phantom 3 Help' started by TCW, Aug 22, 2015.
  1. TCW
    TCW
    Dallas/Ft.Worth
    From the DJI downloads support, that's what I'm getting. Then I extract it to the SD card and follow the DL instructions VERBATIM..on my 3rd attempt, first 2 failed. Well, as I write this the 3rd attempt has failed. Should the .bin file be a VLC media file as it is? TIA for advice. Tim
  2. TCW
    TCW
    Dallas/Ft.Worth
    This is what the txt file reads each time:
    Result: Failed.
    Reboot the aircraft and try to upgrade the firmware again.
    ========== 2014.01.01 00:00:12 remo-con disconnect======
    Packet: P3X_FW_V01.03.0020.bin
    Upgrading ...
    Result: Failed.
    Upgrading ...
    Result: Failed.
  3. doctordrone
    Bay Area, California
    not sure why it's failing, but a .bin file is just an "old school" binary file. It isn't specifically related to the VLC program.
  4. bobmyers
    San Antonio, TX
    VLC is the video file format that is set at default on your computer -- VLC is one of the best free video players and when folks download it to their computer, it will become the default player and place that icon next to the file unless you block that option.
    This is the upgrade file name P3X_FW_V01.03.0020 it is a .bin file and is the file that you place on the SD card for upgrading the firmware.
    This is probably what it looks like in your computer directory.
  5. ghidora
    Bartlett
    i would suggest u try with different micro sd card, made sure format it 1st.
  6. III% Streve
    Delete the old file and re-download it. DJI failed miserably with not doing any form of checks to ensure a file is 100% correct before a flash. Its could easily be corrupted.
  7. TCW
    TCW
    Dallas/Ft.Worth
    Thanks all, I finally got it to load. I formatted the card original to fat32, no good, then formatted it to exfat and reloaded the file, aircraft finally took it.
  8. tandmei
    Has anyone updated and experienced a battery error?? My battery will not power on or off not LED light bars but when plugged into the drone it powers on immediately and can't be powered off...on the mobile app it show battery at 0% charge and says it needs to be upgraded...any ideas???
  9. TCW
    TCW
    Dallas/Ft.Worth
    Just was able to update the FW v 1.3.20, battery functions normally
  10. bobmyers
    San Antonio, TX
    check my other answer in your other post.. you have to upgrade each battery with the FW bin file.
  11. bbfpv
    Long Island, NY
    For those curious, .bin files used to be the file format standard for ripped DVD's (accompanied by a .cue file, which were the chapters) back in the day. The general public has probably never encountered a .bin file prior to owning a P3 so their computer has not associated the extension w/ anything. VLC then becomes the default program associated w/ the file, which is why it shows up in your file browser w/ a VLC icon next to it.
    bobmyers likes this.
  12. TCW
    TCW
    Dallas/Ft.Worth
    Nice explanation..I was having some trouble getting the bird to take the FW upgrade and thought the VLC attachment was odd, like it was trying to make the file a video!? Anyway, since resolved and all up to date.. Thanks
  13. III% Streve
    Its probably pretty easy to get in to. But I havent seen anyone talk about putting effort in to it
Similar Threads - latest P3P VLC Forum Date
P3Pro .. Android Nexus Vers2 - latest Go / FW etc... Litchi keeps shutting down Pro/Adv Discussion Dec 9, 2017
Latest DJI Go not running on Ipad Mini 3 with P3P Pro/Adv Discussion Nov 26, 2017
Latest firmware upgrade for P3P Pro/Adv Discussion Jul 6, 2017
Older P3P rc and ac fw vs latest android lithi software Pro/Adv Discussion Oct 29, 2016
Latest Firmware Version P3P Pro/Adv Discussion Apr 27, 2016
