- Joined
- Jun 4, 2017
- Messages
- 28
- Reaction score
- 4
- Age
- 38
I noticed after powering up my Phantom 4 pro to check the micro SD card on my computer that the camera was pointed level but at a slight angle to the left. It was only noticeable up close and not from a distance. I powered off the Phantom and re-powered it. It did its normal camera check routine by going up and down. I also yawed the camera left and right with the remote and it seemed to be working normally. After yawing the cam, it appeared to be facing more straight forward. I did not hear any abnormal sounds from the camera's motors. There was only one time that I accidentally powered the Phantom on with the camera holder still attached and that was when I was putting it back in its travel case after completing my flight. I somehow hit the battery power button twice while packing up the Phantom. I immediately shut off the drone in the time frame well before the cam could start its camera check procedure. I am not 100% certain if this is the cause. I have heard similar stories about the camera aimed at slight angles. Did I accidentally damage the camera's motors or is it just the way that the camera was designed?
Thanks.
Thanks.
