Is RTH and Failsafe the same thing?
Hi everyone..
In the NAZA assistant, I made my GPS-ATT-ATT switch on the right of the DJI controller 'Failsafe' in position 3.
So now the switch is 'GPS-ATT-FAILSAFE'. Is this ok to do?
Can I just use the switch in the 'failsafe' position to get the phantom to simply return to home? Or should this be reserved for emergencies and loss of signal?
Or is there a dedicated 'return to home' function somewhere which I should be using instead??
-Frank
GPS-Atti-Failsafe is a good setup and its perfectly valid to use it any time.
You then have to set what you want your "failsafe" to be - it can either be "land" or "return to home".
