Is anybody else getting great post production results in D-log?
I've used it successfully with my Mavic Pro Platinum before, but after all the negative comments I've heard and read regarding using it with the P4P, I was very apprehensive to try it with the P4P. I gave it a try, and after some basic color correction, and an aggressive LUT, even with a very novice skill level, the colors really came out great considering what I've heard. The raw footage is so flat, that at first I thought there was no way I would be able to fix it, especially considering it locks your ISO @500, but it really came to life. I've been using normal mode up until now, as the stock footage doesn't need much help, especially if you have your settings dialed in. I think I'm going to keep using D-log, because the end results are better than what I've gotten in D-Cinelike, or normal. I was sure the exposure would be totally blown out, but with a Polar Pro ND16-PL filter, and set to sunny, I was able to dial in the apature enough to get my histogram near perfect.
I'm done with D-log for now. I got very excited at my first post production effort, because the color was so good, but I'm not able to get rid of the noise that a 500ISO provides on further examination. If it's possible to get rid of the noise, I lack the ability to do so. I'm getting the best pre-production results shooting in normal mode, and landscape style of +1/+1/0, 4K/60fps oddly enough.
I'm at a loss as to why your ISO is set to 500. Outdoors should be set to 100.
Reactions: MotorCycle-Man
Because the firmware locks ISO at 500 for D-Log. At least as of some particular firmware update. That’s why he’s done with D-Log.
Because the firmware locks ISO at 500 for D-Log. At least as if some particular firmware update. That’s why he’s done with D-Log.
I've never heard of firmware controlling or "locking" your ISO. Why on earth would it do that?
I shoot nothing but D-Log. ISO never exceeds 100. Phantom 3 Pro.
Reactions: Franky
Apparently, the the P4P is a different situation. I get great color in D-log, but the noise is just too much to deal with, not worth it in the end. I'll probably switch to D-log on my Mavic Pro however, because the colors after post production are just stunning.
Because the firmware locks ISO at 500 for D-Log. At least as if some particular firmware update I think.
Because DJI says that ISO 500 is the “native ISO” for the P4P. I’ll see if I can find a write up on it and post the link here.
Agreed. I finally found ways to reduce the noise after much trial and error, but honestly at this point, I don't think D-log is a valid option for shooting with the P4P.
I’ve been using D-Cinelike as a substitute and like the results. I drop contrast and saturation a little bit though and then boost in post if I have to. Not too much though.
Also D-Log may not be good for these 8 bit cameras. You can introduce banding when you try to stretch out the dynamic range in post when adding back contrast.
Wowzers. I had no idea. Here again, glad I stuck with the P3!
But otherwise the P4P has a much better camera. So I’d rather sacrifice D-Log than sacrifice a better camera.
(ISO is only locked to 500 in D-Log. Not other styles.)
I have a P3 also and am getting much better photos and videos with the P4P without D-Log. I shoot D-cinelike at ISO 100
Reactions: Ripper7620
I like the camera so much on the P4P, that I'm tempted to get the Obsidian version as well, but I'm gonna hold out for the Phantom 5.
AlienzEyes
