IPad Connectivity Issue
I just upgraded my iPad mini 2 to ios 10.3. I attempted to fly my P3P today and both DJI Go and Litchi did not connect. The radio connection was fine (ie. I was able to start up the blades and shut down. That seemed to be normal). I then deleted and reinstalled both Litchi and Go, and same results. I also replaced the wire with another one, and same results. I also rebooted the mini. Same results.
To see it the problem was with the bird itself, I downloaded Go to my Galaxy s5 phone and connected, and it seemed to work fine.
So it the issue appears to be with my mini, and I can only deduce that it was the ios upgrade that did it. Any suggestions on what I should do?
Ok, from reading various info on the subject, I first restored the iPad mini 2 on the pad itself (ie I didn't use itunes) and re loaded DJI Go. Same results. DJI Go still showed no connection, despite the radio successfully connecting to the bird. I also saw that when I did that, the ios version that was still 10.3 (the same version that was on it before when having the problems) . Then I read about a few people that had success when they restored the mini using iTunes. So I tried that. Using that method IT WORKED! Finally I have DJI Go connectivity. I also noticed that ios 10.2.1 was the version after I restored via iTunes. So I continue to believe that ios 10.3 on the mini was the problem. BEWARE OF IOS 10.3, AT LEAST ON THE IPAD MINI.
