extrememc said:Is IOC on by default? If not why? From what I understand about it. It would improve gps mode when using.
extrememc said:Software on remote or quad? Have you enabled yours? If so how do you like it?
It's in the the PT2 assistant software, not the RC assistant. In the advanced tab there is a sub tab for IOC.You would use the RC Assistant software to do this.
CJ31 said:It's in the the PT2 assistant software, not the RC assistant. In the advanced tab there is a sub tab for IOC.You would use the RC Assistant software to do this.
extrememc said:CJ31 said:It's in the the PT2 assistant software, not the RC assistant. In the advanced tab there is a sub tab for IOC.You would use the RC Assistant software to do this.
So I need to download P2 Assistant Sofware then plug in my P2 and change the IOC setting there?
Good point. Forgot to mention to do that 1st.Just to elaborate, its in the top right hand corner of the PT2 Assistant software - click on "Phantom 2" and it will give you some warnings and then change to NAZA-M.
Yes. You should really do this anyway to make sure you have the latest firmware and to calibrate.So I need to download P2 Assistant Sofware then plug in my P2 and change the IOC setting there?
