Which product are you referring to?
There is a much more varied option on EBay. It is a LED light strip, with adhesive backing, that sticks on to the contour of the Phantom. Some are one color lights. What I'm referring to is a RGB a type of strip, controlled by an IR remote.
This means you,can only change the light patter/mode within a short distance from the drone. But, you can have MANY combinations from steady light colors, strobing, morphing from one color to others, chase lighting and MUCH more!
I've purchased one, but I haven't installed it yet. I have another one, for a home project, with a much longer light strip and it is just fantastic!
Rather than controlling just a few LEDs, you will light up your entire Phantom. I also purchased Red and Green, 3 LED light strips that I'm going to add for navigation.
I am also a fan of magnetic body lights. They are round LED lights that are available in strobe, constant and morph functions. They come with 2 watch batteries inside. You simply twist the top portion to turn on the LEDs. They are available in 3 mounting methods.mmthe original ones come with a small, circular, thin magnet that is adhered to the bottom of the light and an extra one. You could glue the free magnet to you phantom and stick on the light when needed. Just don't put one near the compass. My here is a version that has no mounting on it, that you will have to glue it on. I use hit melt glue as it doesn't damage the surface and it is removable. The other method is a clip on, for ears or clothing.
I can provide some sites depending on which kind that you prefer. You can get an idea of what they look like, by doing a Google search for: "magnetic round blinky lights". I use white blinking ones for upper and lower strobes. I also use Red and Green strobing ones to aid in night navigation. The strobing ones can be seen in daylight, for a surprising distance.
I Hope that this helps. It isn't what you were going for, but you might like it better.
