Install P3 pro camera on advanced
Hello friends I am new here, I had reading that it is possible to install the P3 pro camera in advanced, I did here but I can not update the firmware of the pro is failing, the camera I got this firmware 1.9.60 and I'm trying to make 1.11 .20 she even starts to make the whistles D, DD and the led in the camera flashes green and red, then a few minutes the beep is continuous and the camera led is locked in red, then I'll see the result saying that failed asks to try again, I start updating by pressing the likar button then I turn on the drone because in the normal way he doesn't even do the D, DD, D, DD can anyone help me?
You can find the LOG_AB by going to the link in post 2 above and reading that entire post.
44/5000
Look buddy I did the process and just showed it!
  • P3X_FW_RESULT_AB.txt
  • WPSettings.dat
I'm thinking my guimbal is crashing
Any particular reason you think that?
(hint: no it isn't)
it has no cooling cooler
Only a different type of cooler?
Seriously though: both of your statements are so broad that they barely mean anything.
1. Gimbal and camera are merged into one device, and they contain 5 programmable chips in total (6 in pro version). You did not described any symptoms which would suggest any of those chips is crashing. The basic logs you shared also suggest they're not.
2. Some gimbals don't have a fan on them. But that fan is so tiny and ill-placed that it isn't significant anyway. The aluminium cover is good enough in dissipating heat when mid air. It is advised to cool down the gimbal with a fan, or keep it outdoors during firmware update.
3. Ask an IT-proficient person to follow the steps to get LOG_AB for you. If you got one on the SD-card, you got the second as well.
Reactions: JoBe and RodPad
(hint: no it isn't)
I was able to find folder named Mic has several log_ab I separated what I am trying to install to work the 4k camera in p3 advanced
  • P3X_FW_LOG_AB.txt
Make sure this is the correct file. Otherwise further diagnosis is pointless. If it is, look at last entry:
Code:
 [00243997]Version checking[2]...
 [00244148][03 06][00] v2.4.20.50 -> v2.4.20.50
 [00244293][03 05][00] v34.2.0.9 -> v34.2.0.9
 [00244547][04 00][00] v1.48.0.0 -> v1.48.0.0
 [00244729][11 00][00] v1.8.0.0 -> v1.8.0.0
 [00244912][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
 [00245013][11 01][00] v1.8.0.0 -> v2.0.0.33
 [00245161][12 00][00] v1.13.0.0 -> v1.12.0.0
 [00245324][12 01][00] v1.13.0.0 -> v1.12.0.0
 [00245501][12 02][00] v1.13.0.0 -> v1.12.0.0
 [00245662][12 03][00] v1.13.0.0 -> v1.12.0.0
 [00258274][15 00][00] device not detected.
 [00270893][17 00][00] device not detected.
 [00283498][17 01][00] device not detected.
 [00283619][19 00][00] v1.0.8.96 -> v1.0.8.96
 [00283724][01 00][00] v1.32.5432 -> v1.32.5432
 [00283837][01 01][00] v1.32.5432 -> v1.32.5432
 [00296445][08 00][00] device not detected.
 [00296587][09 00][05] v4.1.0.0 -> v4.1.0.0
 [00296696]Packet upgrade failed at version checking.
What you see is the Ambarella module asking other parts of the drone for software version. Some modules responded, others did not.
Modules are identified by 2 numbers - those in second bracket of each line.
Now you can check which modules are inaccessible for the camera. Here's a list of them:
Code:
Ok more what should i do?
In general it would be, but you have two hardware issues:
1. DaVinci requires manual re-flashing
2. VPS is disconnected
Anyway, you should sell the drone to someone with some technical expertise and get a fully working one.
Reactions: JoBe
intertronixlabel
