IMU overheating at normal room temp.
I have a DJI FPV and when powered on it will try and connect for a second and then disconnect. The IMU gets up to 140° F within 2 minutes. I am aware of the IMU heater but out of all the information I have found I have not heard of an IMU heater being stuck on. Is it a problem with the settings, main board or IMU itself? Can't seem to find an answer anywhere. I have heard of people putting their birds in the freezer and having it work. Mine will work better but it still overheats in the freezer. Thanks in advance!
Dji FPV IMU heats up to past 140° F and will not connect to goggles or controller. I tried the freezer technique and it will connect for a minute or two but then proceeds to overheat again. It seems the IMU heater is stuck on. Is there a way to disable the heater or is there something I can do in a settings menu?
All the DJI drones I know about will maintain an IMU temperature of 65° Celsius. That's 149° fahrenheit. I.e., the IMU temperature you're seeing is normal.
Don carlos
