Immersion 5.8 GHZ and Boscam Galaxy D2
Hi Eveyone,
I am trying to connect output from my go pro 4 to my Boscam Galaxy D2 32 channel Monitor.
I have wired it up like the shop told me to and am struggling to tune it.
Does anybody have this set up? If so could you give me some guidance to what switch combination on the back of the moniter I use?
I am trying to determine if it is a wiring problem. I had a thunderbolt transmitter fitted before and changed the wires to the immersion plug.
The shop I went to told me not use the black and red wired plug that goes into the left immersion plug as it draws power from the go pro. Is this true?
And then to attach the yellow video wire to the yellow of the immersion plug and both black wires to the same one (as it did on the thunderbolt transmitter) and then leave the remaining red wire out of it.
Ahhhh as you can see, new to this and really need some tech advice.
Thanks!
