I bet you can't make your Phantom do this... I am making progress...
Where the deer and the antelope play
Winds: less than 10 mph
Loading: gimbal and GoPro.
Weight: about 1150 grams, DJI says max weight = <1200
Temp: about 70 f
Altitude: about 4,500 feet
dirkclod
Moderator
Staff Member
Premium Pilot
Amory Mississippi
I Will call a Dr right away bro :eek:
Reactions: IflyinWY
Point Washington, FL.
You need to perform an advanced calibration via the Vision software. Once that is complete, perform the usual on scene calibration and this yo-yo effect should cease.
Thanks for mentioning that. It's not a Vision, it's an FC40, which is a P1 with a different control frequency. We use the NAZA assistant to do what you've suggested.
Today, prior to the flight in the video, I checked the IMU calibration, it was not needed. I did do a basic and advanced IMU calibration less than a week ago. I lowered the compass on the landing gear by about 1/4 inch today, in an attempt to resolve Yaw issues. It didn't work, but that is the only change I have made in weeks.
I did do a Compass calibration, at the same location, within the hour, prior to the video.
Who's next?
Reactions: dirkclod
Who's next?
Did you ensure the surface upon which the drone was located during the advanced calibration was completely level by using a bubble type level?
I have a digital level I used to ensure the table I used was level to within +/- .02. I used cardboard under the legs of the small table to make sure it was within specs. If you didn't use a level to ensure a stable and level surface, then you may have inadvertently done an advanced calibration that saw your drone being mis-calibrated from the very beginning.
Edit: The calibration being greyed out under the Tools tab isn't always the right indication of a compass cali problem. Performing an advanced Cali on a level surface cured my drone "wobbles" even though the software said it was good.
Why yes I did ensure the NAZA module/FC was very level, I even started a thread on that very subject some time back. I have a pile of soap boxes which I regularly stand upon to preach that very subject. I'm happy to know it's fallen upon receptive ears, or eyes really.
Look at my signature, it includes a link to a webpage I have written on the subject.
I really appreciate your input and hope you keep throwing ideas at me.
Reactions: steveeds
I had not seen your prior information about IMU calibration. However, you've done an excellent job of explaining it!
I would then be wondering if there were external factors you aren't aware of impeding your compass cal. Barring that, if possible, I would check the readouts in the Vision software via a laptop while calibrating to see if the compass is out of specs for the area you're trying to calibrate in.
Did that make sense? I'm fairly exhausted. lol
Last week I watched an excellent video which you can find here:
www.wynotweb.com, it's front and center on the homepage of my website.
I did all of that with my Phantom plugged into my PC. It was kinda fun to watch the numbers go crazy while I swirled the Rare Earth Magnet around and stuck it to my compass.
FYI: I have a new compass enroute at the moment.
I would bet the new compass module will fix your problem. Using a REM near the drone isn't something I would do. Did you degauss the compass after doing that? Perhaps a good degaussing would put your original compass back to flight standards. Otherwise, if the original compass isn't bad, I'm at a loss as to why you've had such issues.
I'm at a loss too.
Tomorrow I will pull the gauss plug and see if I can degauss it.
For tonight, I say G'nite and thanks for trying. I'm tired.:D
Reactions: dirkclod
I'm at a loss too.
Me as well. Tried going to sleep a while ago and look where I am! LOL! Nugging things out with you about possible issues. *sigh*
To sleep as well as I did in my 20's!
Reactions: IflyinWY
Yea, that'll happen...
Reactions: BlackHawk388
Temp: about 70 f
1200 grams is 1.2 kilograms or 2.2 lbs. That's a pretty big load. Wow!
Hey Robbie,
Have you weighed your Phantom?
I have a P1 arriving today and I will weigh it.
I'm thinking 1 Kilo = 2.2 pounds.
Hey Robbie,
Would be very interested in what you find. I don't hae a scale that can measure something that light. Just human scales.
I was using the Naza software and it notified me that firmware v4.02 was available. I did the update, recalibrated the IMU and compass and then I couldn't control the copter. I crashed three times in a row. There are storms in the area and I wonder if the electrical activity in the air was causing me problems. I hope it's not the update that caused it because I don't know how to take it back to the last revision of firmware.
Anyone have any thoughts on this. BTW, the wind hadn't been bad at that point. I gave up when the wind started picking up.
West Coast of Florida
Was it doing this before you moved the compass? You mention fixing a yaw issue. Did you move it back?
Reactions: IflyinWY
I didn't move the compass, just recalibrated it. The bird was flying fine until I did the firmware update.
Please define "moving the compass".
The compass isn't moved unless it's a few hundred miles from where it was initially calibrated. Technically, it is moved each time you're more than a few feet from where you last calibrated it. All of the known, correct, information out there shows that a new compass calibration isn't required in less than a hundred kilometers. Most say less than 300Km.
So please. Be specific.
New Threads
Gilmar Souza
