How to improve fpv distance?
Hello all
I currently have a fly sight 400mw tx and a black pearl both with standard antennas and loose fpv about 130m .
What can I do to improve this to lets say 600m?
Would a spironet antenna give me this much increase? Many thanks,
Shaun
pucka.costello said:
Hello all
Shaun
youtube fpv antenna upgrades..
but my thoughts are upgrade the stock whip antenna to ibcrazy clover leafs or mad mushroom.. and also consider a helical directional
jasonnelson007 said:
Fpvlr all the way. Just do a little research.
+1
There are many people using immersionrc 600 and black pearls getting well over 3000m, which batteries become the main problem. Have a look in the fpv section and you will find testing with different Ariel's makes all the difference
Personally I use the Horizion Nimrod on the phantom and Pearl with a Black Hawk on the pearl
Here you go, read the first few pages to see others have the same problem then skip to page 50
viewtopic.php?f=31&t=8406&p=205670&hilit=horizion#p205670
Simon
I don't know if you thought about it. I didnt until yesterday.
Keep your parameters further away from each other.
Before I was loosing my wifi fpv at around 300m with a re-700.(equal to a re500) with the phantom set at a max range( radius) of 1000 ft. It might have been causing the breaking fpv connection I had before.
I reset my parameters for a 2000 ft. Range and took a full flight never loosing video this time.
( going into continuous capture)
If you flying P2 vision+ using wifi is fine but this a P2 non vision thread and using wifi is a no no due to the fact wifi and the P2NV use the same frequency 2.4GHZ
I followed Jason's lead and installed a Fatshark patch and a Fatshark clover leaf on my Blackpearl and the matching Flatshark clover leaf on my P2's video transmitter. I just flew it about an hour ago and got 1375 meters with the P2 before fail safe took over. The video was still pretty good though. Now I might have to upgrade the controllers radio. Living in the wide open country just begs for distance flying (within reason anyway). I'd like to go a mile without hesitation of my equipment's capability.
jk
jorge sanchez
