Re: How to fix a vibrating / shaking / crazy P2V+ camera gim
Hi guys,
Unfortunately i crashed my phantom and have the same issue. Camera has rotated against the x axis pin. I have no damaged parts and no bent parts. My props are perfect. it was the smallest crash. When i unscrewed the back like the forum suggest i alligned the pins flat surface. it seems to be the problem im having. it worked for a bit and started going crazy again. i did not use jb weld yet. i will be taking it to a technician to fix the problem.
Can install a different gimbal on my pv2+? can i switch to a zenmuse gimbal? is it easy to switch?
Hi guys,
