I decided to fully set up my Phantom 2 with my FPV kit from Kumbacam and my Zenmuse H3-3D gimbal.
First of all I do not want to open my Phantom in any way.. I just do not feel comfortable doing that as I am worried I might damage something.
Keeping that in mind I have a couple of questions.
http://www.youtube.com/watch?v=yOoU-RftvV8
The Zenmuse: see here after 0:56 "Connect connection cable with camera mini USB port" - this is the connecting of the video output board connector to the mini USB port on my Go Pro hero3+.
But of course I have to connect the FPV screen also to the Go Pro's USB mini port as seen here after 0:55 http://kumbacam.com/Basic-FPV-Monitor-Kit .
There is only one USB mini port on the Go Pro... so how am I supposed to fit both cables there?
Do I need a port hub which I plug into the Go pro and then it has two USB mini ports on the other end?
What role exactly has the video output board connector on the Zenmuse have? (has it to do with the anti interference board?) Do I need it plugged in as I first and foremost need the video output from the antenna to be connected to the Go Pro for the image to appear on my FPV screen?
2)
for bonus points.. ;-)
Does the Zenmuse anti-interference board need to absolutely on the bottom of the body.. The FPV battery and the antenna are that big that the anti interference board won't fit there as well, but the board is small enough to fit on the side right by the bottom of the body. Will it do its job just as competently there?
Hopefully you can navigate my way out of this one..
2)
