How to find DJI Vision
Gananoque, Ontario, Canada
DJI GO won't work on P2V+. and Lichi for P2 crashes so often it is useless.
I have followed around 6 different links to Vision, some at Dji, others 3rd party, but none will download to my Galaxy Tab S3.
Any suggestions?
This is most likely due to the device you are using. It is far far too slow and barely supported via Android at such an older level.
I would try another device first.
I'm a bit confused about that, I'm using a Tab S3, how does it work on your older Tab S2?
My fault I missed the "tab". Only saw S3. Anyway, you will still need to use the Phantom 2 assistant I would suspect. One last question. What version of Android is on your Tab S3?
