- Joined
- May 14, 2016
- Messages
- 148
- Reaction score
- 22
- Age
- 46
GL300E: Built-in display device (5.5 inch screen, 1920×1080, 1000 cd/m2The phantom 4 pro + (plus), how many nits? Just wondering how it compares to crystalsky.
It's 1,000 nits. You can find more details about the P4P+ remote controller here.The phantom 4 pro + (plus), how many nits?
Have you ever wished it was brighter ?Exactly what I did and very happy w/the 7" model.
A bit heavier than I thought it would be, but not unmanageable.
The batteries seem to last forever.
I assume you also used the replacement mounting kit for the Crystal Sky, correct? If yes, can you tell us about the installation? I expect that mount by itself to weigh quite a bit, it looks very beefy. Was it straight-forward to remove the old clip stand on your RC and install that new base mount for Crystal Sky?Exactly what I did and very happy w/the 7" model.
So have you tried to play your 4K drone video, inserting the SD card in the Crystal Sky and output it via HDMI to a 4K TV, using the Crystal sky as a video playback unit, detached from the RC? For me, that's a unique feature (if it works) that adds great value to that product.I will echo other responses here, with the sun to your back, it is still totally visible, and not one glitch or random boot ever.
The mount is actually very light, and what is interesting, when you are flying, the perceived weight of the unit seems to vanish, I never thought is was too heavy when flying, only when handling it at home does it seem to have a bit of a heft to it.
So, when you say "sun to your back", does this mean your screen is in the shadow of your body? Or are you saying with the sun from behind shining on the display? I look forward to seeing one of those devices in the outdoor sunlight.I will echo other responses here, with the sun to your back, it is still totally visible, and not one glitch or random boot ever.
When there are no trees to find shade, I fly with my iPad in the shadow of my body all the time to maximize screen visibility, that's why I ask. I also use umbrella's sometimes, clamped to my flight chair.
Would you mind clarifying?Hi John,
Full sun beating down on the screen, still looks good.
I do not have a 4K panel, but ran it through an HD panel. and the picture is super letterboxed. Both top and sides have bars, but the pic looks good, some small moire, but not bad.
The CS stays on the whole time, and there are navigation controls on the CS.
You can also play the cached video, and the sound comes through the HDMI and plays on the destination, the CS speaker is muted.
HTH
Did you play 4K video through the CS via HDMI to a 1080 TV? And this resulted in black bars top, bottom, left and right? Have you tried playing 1080 video to a 1080 TV?
When you say the CS stays on the whole time.... you mean you left it on attached to the RC the whole time? Can you confirm it works the same when detached from the RC using it's own battery? Of course the CS has to stay on to play the SD card, and you'd need some menus in the screen to choose settings (I assume) and start and stop the video, as well as select which video file you want to play from the SD card, right? Is that what you mean, the CS screen is always on?
If it plays 4K SD cards through HDMI to a 4K TV, that's going to be very useful. That's what I'd like to confirm for functionality. The other huge question is, will it also decode H.265 files from the drone and play them to a 4K screen? The manual says it does, but we all know DJI fudges sometimes. I'm very curious how well this works, because there's nothing else on the market that can conveniently play drone SD cards to a 4K TV (via HDMI) with H.265 encoding in h/w. That's bleeding edge today.
Today I couldn't buy one of these CS tablets due to incompatibility. As of today's release notes, the new CS firmware requires craft firmware V02.02.09.00, and I'm not going there for a while.
Hey, good info. I'm surprised of the lag and/or slowness of H.265, as this codec is touted to be a more efficient compression technique. Maybe they meant efficient in storage space, and it's more difficult to decompress. Interesting observation.Certainly.
I tried 4K, 2K, and 1080, all H264, all going to a 1080 panel. All looked the same. I have attached a screen shot of the crop.
re: "stays on the whole time...." - Yes, I removed the CS from the controller, and it does stay on the whole time, which makes total sense now as you need to control the video, I guess at first I thought it would go off, like screen mirror or something along those lines, so this is good.
I next tried 4K H265, and it does indeed play to the 1080 panel "almost" just fine. There is some lag, and it seems like it is running at about 95% speed. When playing on the CS, it is fine, perhaps down converting to 1080 was the cause, but I cannot give this a valid test as I do no have a 4K panel.
Hope this helps!
Rick
Oh yeah, my flight chair serves 4 purposes:John, that's the first reference I've seen to "flight chair ". Took me a few flights before I realized sitting down was a much more relaxing position to fly in.
