How do you power 3rd party gimbals on P2?
I have GLB 3 axis gimbal. I am not sure how I should power it. I have P2, version 1.
Can I get away with using these power wires for video transmission? See pic. And if so, how do I distinguish between the video ground and power ground?
Or do you guys try to tap to power source somewhere inside? Are there any good points? :?:
Help, fellow Phantom owners.
Most folks w/aftermarket gimbals are tapping into NAZA F2 port to power the gimbal. Top pin = ground, middle = positive, bottom is signal (for tilt)
In one of the legs of the Phantom, you'll find an Aux power cord, which has 3s power that can be used to power a gimbal and FPV.
..the NAZA F2 is used to control the tilt - you'll want to connect to the signal of that. , (it only has 5v of power , which is only enough for older servo gimbals.)
jack klausner
