May I suggest do the following test for ALL the props.
Turn one tip of the prop until it positions right over the shell, then look at the gap or space between the shell and the tip of the prop. This should be about 1/4". Turn the other tip of the same prop to exactly the same position on the shell and see if the gap is EXACTLY the same as the other tip? You will be surprised!
! If not, then either the hole of the prop is off or the motor shaft bend or the motor is not fully seated or combinations of these.
Some carbon fiber props with untrue hole can be slightly adjusted by filing off the hub material on the high side.
If you fly with soft and thin after market plastic props, you may want to check the blade tracking just like the rc helicopter flyers do. Defective props will only show this ill effect while the props are spinning, so be careful.
You can hover at eye level and look at the tips' arc and see if they line up or one is higher than the other. To help visually, you can use the different color Sharpie painted the tips.
I tried the 3 blade plastic props and found out that the standard black ones, especially with carbon particles seem to have better tracking than the pure plastic color ones. The thinner the blades are the better chance that they will be deformed from the injection molding process, some of which are so obvious that you can clearly see the tips are out of track just by spinning the blades by hand!!
