Hovered at 1.2m but controls unresponsive 1st Flight
Discussion in 'Pro/Adv Discussion' started by Philistin, Jul 11, 2016.
  1. Philistin
    Its the first time I've taken the P3 pro out for a flight, all the calibrations go well and I swipe ok for take off. The P3 rose to 1.2m and just hovered, the sticks are unresponsive, so after a 3-4 minutes I press land. I switched everything of and tried again. When I press take of a little window appears saying that the drone will take off and hover at 1.2m. Help what am I missing - the hand brake ?
  2. Wolfiesden
    Milwaukee, WI, Ft Walton Beach, FL
    Go to stick configuration and make sure custom is not selected. If custom is selected, make sure the controls are actually mapped. That happened once with me. Custom was selected but GO didn't save the stick settings so the sticks were not mapped. Other than that, not sure what to tell you.
    Philistin likes this.
  3. GunnyPapa
    Does the bird take off normal without using auto take off?
    Oso likes this.
  4. Wolfiesden
    He is probably like I was. I didn't want to manual takeoff until I had some stick time and confidence. And yes, I know takeoff is easy manual. You don't know that at first though!
    Digdat0 likes this.
  5. Philistin
    It was a RC calibration problem, sorted now. Required a firmware update. Thanks for your responses.
    GunnyPapa likes this.
  6. GunnyPapa
    Great to hear you got it resolved!!
Similar Threads - Hovered controls unresponsive Forum Date
P3 Standard - Litchi mission AC stopped & hovered for 2 mins Control (Go, Litchi, etc..) Nov 3, 2016
Lost Signal, P3S Hovered Instead of RTH Standard Jan 1, 2016
Phantom over water (loss control) just hovered then splash Phantom 1 Help Jan 29, 2014
Controls under RTH or forced landing Phantom SE Dec 9, 2017
Professional Phone Controls Lock Up Only When SD Card is Inserted Phantom 3 Help Nov 10, 2017
