Home Lock, Course Lock
London UK
I finally enabled the Naza mode to have a go at ATTI and HL, CL.
I'm a bit confused, maybe need practice on it.
-HL seems to work but if I use it for circular shots, the radius seems to move quite a lot, and the speed has to be quite slow apparently.
-CL seems to do its job as well but right stick is inversed ?
I definitely need practice on this. the goal is to pan at 180 degrees on a moving target... Wah! :shock:
HL is more of an arc than a radius. CL is great for keeping things moving is a straight line whilst you pan - the aircraft will sort out whatever it needs to do to keep tracking on that course. There are some types of shots, though, that can only be done by a skilled human being... certainly one above my pay grade usually!
jeetbuzz360
