Hoem lock and course lock settings.
sorry for the typo. I meant to type HOME lock. In order to use home lock and course lock, do I just move the s2 switch from the off position and that engages Home lock and course lock depending on the position of S2 or do I have to do something to set the s2 switch to operate course lock and home local
Thanks
You have to switch from the Phantom mode to the Naza-M mode on the assistant software and then enable IOC.
Ok Thanks, How does that effect GPS mode? Everything will be stable or Atti?
If you have both S1 and S2 in the upper most position, it will function the same as in Phantom mode.
Jesmith1016
