Help with Taranis and Lightbridge
I'm hoping someone out there can help me figure out how to use Lightbridge with the Taranis Tx and X8R receiver. The Lightbridge connects to the X2 port where the X8R RX is supposed to go. Now I'm stuck and not sure where to connect the RX if the Lightbridge plugs into X2. Would I use a different port like X1? Thanks in advance!
You don't need the 8xr, you plug the lightbridge into the x2 port, them the ground unit into the taranis via trainer cable then configure with lightbridge assistant.
