Help...cracks spotted
As for potential voided warranty, I'll just change out the shell if I need to send it in for a warranty claim. Hopefully I can find a bottom shell by itself without having to get a full $60 kit. There won't be too many situations though I would bother sending it in that might otherwise be cover under warranty.
Hi everebody I've just tried to purchase plast-aid and found that Amazon due to unclear restrictions cannot ship this product to Italy. ...I'm stuck..
..tried to contact them directly...it is a palestinian company...I'm afraid I can't find it in Italy... will see other options....do you find in normal stores in the US?
Yes I just went down to the local pool/spa place and they had it in stock...I'm sure you can find it on plenty of sites on-line besides amazon...
...it looks that also ebay doesn't ship.to Italy..
You know this sound "idiotic". But if you knew someone reputable at another location they could forward it to you if your that desperate.
..that's it...hope it will work...not sure if powder was enough but wanted it liquid to fill all spaces....
I fill mine a little further over then that but still not touching the side because that's where the top lip comes down. I put a piece of tape around the edge all the way around then poured it in. I just tried to get a even coat all the way across and not miss any spots. Worse case you would have to grind a little off with a dremal tool if the top shell hits it. But
hcashmore11
