HDMI Output on a GL300L
Does anyone know if there is an adapter that will add an HDMI output to a GL300L controller?
DJI hasn't released an HDMI output module for that remote controller. You could use a mobile device that has an HDMI output (like the Nvidia Shield K1).
Micro USB to HDMI plug or cable. Available at Amazon or eBay. $6.95 up. Cheap, easy.
Works for me. Cheap enough that he might want to try. He might be happy, maybe not. Buy from a US seller that takes returns. I’m outa here. See ya.
Why not let him know exactly what you're using with your GL300L before you head out?
Bought two. eBay $6.95 each. Good luck. Hope you find a solution that works for you. Says Samsung, doesn’t matter. Other brands, same.
When using this type adapter, plugged into your RC, it should automatically work with your GO4 app Android device, to HDMI. With iOS, you might have to go into HD settings, at the bottom enable USB and HDMI output. Have fun.
