HDMI for P4
I used my Inspire 1 remote controller since it comes with an HDMI out.
Oh ok, I'm gunna install mine myself. I've watched all the YouTube vids on it n it don't look that bad. I'll keep u posted when I get it done
Hay msinger I can't find anything in the Go app to get my sharks workin
Enable this setting in DJI GO:
And, then toggle this button a few times to get it to the correct mode:
I will try that later today thanks buddy[emoji106]
Good too hear. I get my bird back on Friday can't wait to hook up the hdmi. Did u install ur hdmi yourself?
No problem to install the board. There are some YouTube tutorials out.
After installing the board, I had to update firmware on my transmitter - that's all.
Have difficulties to see the top right corner with the OSD display in the goggle.
All other works very well.
Don't forget to switch from follow mode to fpv mode in the DJ GO app. Awesome!
You don't see the "HD" section at all?
I found it, still don't see anything [emoji848]
Can you explain what you tried in detail?
Now that I found image transmission settings and switched the simultaneous image do I change channel mode to custom also?
Channel mode has nothing to do with hdmi output. You might want connect TV monitor to confirm HDMI signal is present. If not possibly HDMI module tiny connectors issue.
Note I use Fatshark Dominator and power on them after all set so google automatically select HDMI input (otherwise I select manually input on the google)
The only setting you must change in DJI GO is the setting I drew a red box around in my screenshot above. Everything else can remain as-is.
Okey dokey I'll try again. I try end
I tried to call DJI bout this n they said they can't give info on how to use fpv goggles [emoji35] WTF
What exactly doesn't seem to be working?
Goggles won't sinc can't see anything
I get all the info ( batt, Hight, distance, horizontal) but no picture
Did you try clicking the "Display" button the goggles? I have to click it a few times to get to the HDMI input.
Nothing, I scrolled through 5-6 times [emoji53]
BellpDrone
