- Joined
- Apr 14, 2015
- Messages
- 3,534
- Reaction score
- 2,041
- Age
- 49
yea I hear you. I would not trust a .99 cent props.Yeah theyre pricey but dont trust the aftermarket ones
Db what was your setup today? looked like you were getting windyhttp://www.flytrex.com/mission/quadcopter-phxbird-2--blake-beard-IqxuKvny/
****, Phoenix, if I don't get back out there soon with my P2 you're going to catch up to my record. Was that a Litchi flight? What you land with %? Was using that external bat? Great distance for the P2v+. Nice PB bud[emoji41]
I was talking to a local hobby shop tech and pretty much said the same thing Db. He said a little more lift but more vibration and will see it in the camera.If you want to try CF props, they may flex a little less, but I don't think enough to make a difference, keep in mind I carried some serious weight. From my experience I would strongly recommend you do not use the aftermarket CF props
Good to here, need you up and running. Db's already back at it with his P2v+. this morning he clocked 3.4 miles runUpdate - I had some time and tested my P2V on my kitchen table today. Everything seemed to work okay including flytrex (even though I found two of the flytrex canbus cables got pinched between the two plastic halves). But when I started the motors, the two that melted the plastic wouldn't turn and I smelled a burning smell. I had already decided to swap out one of the motors to be safe but now looks like I'll need to swap out both.
No biggy - just more delay and lost flight time...
Don't let him know that. He might start to think we're all groupies.Wow good for him!
My fantasy vacation would be to go to Iowa and hang out with DB for one week.
This hobby is cheaper I think?
Hello The gentleman was half right about the Gopro. The gimbal is trying to balance out and knows some is wrong ( no weight). That is why it's jerking. You can do a few things. If you are not going to put a Gopro on it ( right now). unplug the gimbal and take it off. two things will happen no more movement with the gimbal which can be throwing the balance off of you drone ( jerking around) also longer flight time per battery ( lighter load no gimbal). I did the same thing with one of mine. I just unplugged the gimbal and removed it taped the wired to the bottom of the case. After that I would try and do the firmware update again. Sounds like you may of not completed it There is a few video's on Youtube on how to do the firmware update.Dear phxbirds57,
I read your thread and you seem like you know a lot about the phantom 2 and how you fix them up. I know nothing about the phantoms and I think i messed up my firmware/software. Here's what i did. I just picked up my first, used, P2 with the DJI Zenmuse H3-3D factory installed. No gopro camera came with the p2. I went flying but could not get a good connection and the gimbal was jerking all over the place. (What do I know). One of the guys at the part told me I cant fly with out the go-pro camera installed as the bird needs it to complete its start up. He also told me I need to update the firmware,....to which I did,.....with no go-pro camera installed. Now when I turn it on the p2 the light sequence stays in a perpetual "Power On Self Test" phase, (red,green,yellow) Sooooo,...in short i think i really messed this thing up. How do you recommend I fix it? Thanks in advance for any help you can offer. - Jim
in short no. weighs more than the newer version and the gimbal plugs in to the gopro and I don't think it lines up right. If your looking for good video and pictures or just to learn to fly ? just learning to fly and would like some video. buy a runcam or mobuis camera ( $50 & 70) no it's not a gopro but it's cheaper and gives you a good video with a good mount. if you do this remove the gimbal find a vibration plate on ebay (about $10) with rubber balls. rubber band the camera to the bottom and your good to go. once you get the hang of flying step in a P3 or even find a good P2 vision plus.You mentioned version three or four and I believe you're referring to the go-Pro correct? How about a go pro 2? With that work? now $140.
darn I was a fraud of that.Update - got the motors today but they aren't turning. So I guess my ESCs are bad and I'm gonna order new ones right now!
been there, I had to strip and older drone for parts.Yeah - the two motors jiggle a little but won't do anything else.
