Hi all - I have a leftover P3P transmitter (the 300 version). I've heard it has better range than the P4 transmitter.
Can the 300 be linked to the P4? If yes, any known problems?
If you are looking for range , the best solution is one of the dbs itelite panel antennas. Jake @ Maxxuav.com was great to deal with . Very knowledgeable and professional .
RC firmware is the same for P3 and P4.....if you're using an old RC from your P3 which has not been used for a while, you may need to update it to 1.6 if that's what your current set up with the P4 is using.
