GPS lock without GPS lights !
I'm slightly worried about the sequence of lights I see on warm up of my Phantom.
From cold I get the usual warm up flashing for a minute or two, then I get the usual 8 or 10 flashes to tell me it's warmed up properly and then before the red GPS locating flashes, I seem to get the home lock flashes.
Instead of waiting for the 6+ satellites before home lock?
The reason why i'm not overly worried is I always perform a manual home lock once it's got 6+ satelites.
I'm just confused why it should indicate a home lock before GPS satellite lock.
Please help.
Yea I noticed the same with mine too. More satellites essentially means better positional resolution, particularly height. To mark home-position 3 satellites is actually enough so that's why it marks it prior to 6+ satellites.
2 satellites can give you a 2d positional fix without height, 3 satellites gives you a Lat/Long/Height fix, more than that and it's all about accuracy.
Even though I get the home position acknowledgment I still wait for the RED Led to quit flashing before I lift off, I don't think it updates the home position but I just feel better about it.
I got the same situation. Rapid blinking Green before GPS lock. I wonder if it records the true take off location before GPS lock. For several times, I failed to pull back my phantom with IOC when it's far away from my sight. Is that related to the rapid green before GPS lock?
Since I do not know for the fact that the rapid GREEN is a successful CL or HL or both, I always perform the manual settings for both afterward.
DonT
