i attempted a gimble calibration after a imu calibration. The gimble calibration was going ok until it got stuck at 50 percent. Any ideas please? I have powered it up twice with the gimble clamp on.
What did I say to make you think I tried to calibrate with gimble clamp on?You should absolutely not calibrate with the gimbal clamp on!
Thanks CJ, my boot as not sticking out so with owner off, I gently moved it in all directions but that didn't seem to fix it. I will call Sure RC , they have been very helpful in the past. I haven't updated in 3-4 months, maybe that will do it.The same occurred to me - stuck at 50%. I did two things. First I noticed the rubber dust boot (sorry don’t known what it is officially called) at the base of the gimbal was partially hanging out. I gently tucked it back in. Second, with the unit powered off, I gently manually manipulated the camera and gimbal around to its full extent on all axis. When I booted back up the gimbal was able to complete the calibration. I suspect there was some resistance that the gimbal motors could not power through. Video has been smooth ever since. I hope this helps.
