- Joined
- Aug 18, 2017
- Messages
- 26
- Reaction score
- 1
- Age
- 24
I’d very strongly recommend you replace the antenna wire ... do not try to repair it. If it were me, I’d replace the black antenna wire also as a precaution. Double check the ribbon wire as well with a magnifying glass to check its integrity. Sometimes they can have a fracture after a crash. They are relatively easy to replace. Good luck.
Yes it is a coaxial cable. Nearly impossible to repair. The part cost about $18 us. Have to remove the cover to do the replacement. It's not difficult to replace. I wish you luck in finding the parts.
Yes bro everything works fine but you shouldnt fly it cause i dont know exactly but i read its calld RX Cable and if you fly it unconnected then electiricity coming to it will burn your drone something like that. So dont fly without repairing.
And heres the question it works just fine with one antenna, so when we replace second antenna how we would know if its working?
I can’t swear to it, but I’m thinking it won’t burn your drone. If you don’t have either antenna connected, it might cause some damage, but I would think one antenna is enough. I must insert the disclaimer here that, you try this at your own risk.
Just the fact that you have already flown it several times like this tells me it will work. I think that if it was going to burn your drone, it would have done immediately when you flew it before.
