Gimbal vibration help
Siloam Springs
I've had this vibration since my first flight. No crashes. All packing material removed. I've had about 20 flights and the vibration shows up on all my flight videos. IMU and gimbal calibrations completed several times.
Thanks for that. But my gimbal vibration is very small and consistent. I've searched the entire YouTube planet and can't find a similar problem. Seems like the motors are continually trying to adjust.
Right. You should check the alignment of all the gimbal motors. Sounds like the roll motor out of alignment. Can you tell which motor is vibrating? That's the one you should check.
src72
