Gimbal lock and ND filters for P3S
Do you have first hand experience with the stuff you add on the site or is it based on other users?
Yes. It's a mix of things I've tried and a ton of research.
http://www.ditzco.com/products/3-pack-neutral-density-filter-kit-for-dji-phantom-3-quadcopter-drone
My ND filter Kit from DitzCo Will Fit the Phantom 3 Standard. The outside dimension of the lens barrel is the exact same for all Phantom 3 models. The main difference being the Standard does not have a removable filter so only a slip on filter will work.
Also I test every single filter kit that goes out before I ship it to make sure it fits. I also offer a full refund if you don't like it.
I can't speak to the gimbal lock though.
thanks
-david
Reactions: Jay H
You have to be careful & order a gimbal lock & filters made specifically for the P3 Standard as it is NOT the same dimensions as the P3 Pro/Advanced. I just received a gel filter set from DitzCo. Very nice & a great price but it only fits the Pro/Advanced. I did drop Dave a line suggesting he make a set for the P3 Standard & will let you know what he says.
3-Pack Neutral Density Filter Kit for DJI Phantom 3 Quadcopter Drone
My filter kits Do Work on all versions of the Phantom 3 including the Standard. I do not offer a gimbal lock so I can't speak about that.
Dirty Bird do you have a Phantom 3 Standard and found that my kit does not fit? I test every kit for fit before it ships so I would like to know why it does not work?
Thank you
-david
I didn't measure the barrels. But, I can tell you all of my P3P accessories fit on the P3S camera.
I did measure the lens barrels for the Phantom 3 with a digital caliper and all the cameras are all the same diameter.
Thanks msinger :p UAVbits does not ship to Norway and the other two wants over 30$ in shipping :eek:
Think I need a 3D printer :D
Thank you for your order. The filter kits I sell will work great on your Phantom 3 Standard. Norway is the fourth largest country as far as sales that I ship too.
thanks again
-david
No I have a Pro & an Advanced & they fit fine. I don't have a Standard so I was unsure if they fit but apparently they work just fine. I like your filter kit. Small, compact, simply to use, great price, and the tabs for handling the filters without getting fingerprints on the lens is brilliant. Well done!
Thank you
-david
ctlfreak
