Professional Gimbal Issue
Discussion in 'Phantom 3 Help' started by Dannynkc, Aug 8, 2015.
  1. Dannynkc
    Near Kansas City
    I've updated to the newest firmware, both aircraft and controller, and have been flying it the last couple of days just fine. This evening when I took it out, the gimbal is making a small jerking movement counterclockwise as you are looking at the display, then back. It wasn't doing it at all in the previous flights, I tried calibrating the gimbal, but hasn't helped, please help me troubleshoot this, as it is, the video is completely useless. Thanks!
  2. bobmyers
    San Antonio, TX
    check the set screw on the gimbal mounting to the base of the gimbal mount. There are postings on the forum regarding this screw coming loose.
    http://www.phantompilots.com/thread...ed-clicking-noise-and-more.49173/#post-462410
  3. Dannynkc
    Near Kansas City
  4. bobmyers
    San Antonio, TX
    Could you post a video?
  5. Dannynkc
    Near Kansas City
    I will try later, I need to jump off here and finish up a couple of chores
  6. Dannynkc
    Near Kansas City
    Here is a link to a video of the gimbal issue:
  7. Dannynkc
    Near Kansas City
    Can a small video file be uploaded directly to post?
  8. bobmyers
    San Antonio, TX
    Looks like it is receiving a regular signal causing this twitch.
    1. Do an IMU calibration and then a 2. gimbal calibration and see if the helps.
    Dannynkc likes this.
  9. Dannynkc
    Near Kansas City
    I will try that in the morning, but why would it change from from yesterday?
  10. Dannynkc
    Near Kansas City
    Had absolutely no issues before the upgrade! Over 70 flights, no issues, flew as advertised...might consider going back to previous....I hate Fing with updates!
  11. bobmyers
    San Antonio, TX
    I don't have the why's but maybe a possible solution-- I was having some gimbal issues on mine and after I recalibrated it and the gimbal-- two separate processes-- they went away.
  12. Dannynkc
    Near Kansas City
    Yes, I will try it..again, it's a real pain to get it cool enough this time of year for the IMU, so I don't get long warm ups, looks like the low temp. tonight is 78 where I'm at
  13. bobmyers
    San Antonio, TX
    I did mine inside with the ac running at about 69 degrees-- worked with no issues.
  14. Dannynkc
    Near Kansas City
    I can't get mine that low, but possibly 72 early in the morning, wish me luck, and thanks for the replies!
  15. bobmyers
    San Antonio, TX
    keep us posted
  16. anthgarc
  17. Dannynkc
    Near Kansas City
    Good luck getting any help from them, please let me know what you find out if you do get through to them
  18. Dannynkc
    Near Kansas City
    UPDATE: I calibrated the IMU, and the gimbal this morning, took it out for a test flight, and it all worked as it should. I am still not understanding why the problem occurred, and makes me a little concerned that it might happen again when I need it the most. We shall see. gotta love modern technology. anthgarc, you might try it again and see if it corrects your issues, good luck!
Similar Threads - Gimbal Issue Forum Date
Phantom 2 Vision + Gimbal issue Phantom 2 Vision + Help Aug 10, 2017
Gimbal issue when flying to the right Phantom 4 Pro Discussion Jul 29, 2017
Latest FW 1.11 gimbal stability issues, please help Pro/Adv Discussion Jul 27, 2017
Standard Gimbal Issue - Cable too close? Phantom 3 Help Jul 5, 2017
P4 pro Gimbal issue Phantom 4 Pro Help Jul 4, 2017
