Gimbal H3-3D noise, and floating
Hi,
I have Phantom 2 with H3-3D v1.0 - IMU 1.0.0.6 gimbal and Gopro Hero 3 Plus Black Edition.
I have problem with gimbal. When phantom starts gimbal seems strange sounds, also when i tap gimbal do the same.
https://www.youtube.com/watch?v=hCF-OTh ... e=youtu.be
in the normal state they looked fine. but during the flight when phantom going sideways gimbal does not stick to the horizon.
Example film is here https://www.youtube.com/watch?v=BRruMhJ ... e=youtu.be
Could you give me any suggestions?
Best Regards,
It looks like you have four anti-drop pins in. You should only have two of them or it will hit them. You could put a ziptie there if you wanted.That is what I did. Also check that the gimbal is not rubbing the battery. Most do and will need to be taken care of one way or another. But you can not run all four pins in it.
Don carlos
